''cat 303cr No pilot controls
Wen32FAB
USA
I have a 303CR, serial DMA-05055. I have been trying for a while to diagnose hydraulic or electrical issues. I have the unit running now and all electrical issues seem to be fixed. But, I still can't figure out the pilot controls issue. Blade functions as it should but I don't have any other hydraulic controls. If I crack any hose connection on the unit I get flow from that hose but no pressure. Hydro pump is strong and will load up when blade is bottomed out or raise to max. I have voltage at safety solenoid and it seems to be energizing. There is a buzzing sound from the main valve block area which I can't quite pin point. Like a relief valve is bypassing? I have zero pilot controls.
Wen32FAB
USA
Hydraulic lockout is functioning properly. Pump has flow but no pressure. Blade functions but no pilot controls. I am stumped!
Wen32FAB
USA
Not yet. I did find the suction screen in hydro tank was stopped up which I cleaned. This resulted in more hydro pressure at the pump but still no pilot controls. Hope this helps. Please post if you figure anything out.
zpollard2017
Linden NC
Shoot me your number! I’ll just give you a call. I did find somethings today that might help bounce ideas off each other. We have the same exact symptoms and the same machine.
