I've got a 2 year old Cat 304E at work that until recently has not been used in loose soil. The past couple weeks I've been working in sand and loose fill and when moving the machine and turning I hear a bang now and then coming from the track drive sprocket area that shakes the whole machine. I'm guessing the noise is dirt in between the sprocket and rubber track. The track has slots cut in it so dirt can be squeezed out when passing by the sprocket but I suspect the dirt is causing the sprocket to jump a cog from time to time.
I don't have a lot of experience on tracked equipment but I can't imagine what I'm hearing is a good thing. I've got the track tensioners pumped up with grease so they aren't loose. Is there a special way I should be turning in loose material to prevent this from happening?
