I've got a 2 year old Cat304E2 at work that gave me trouble for the first time yesterday. I was attempting to switch attachments and all the red warning lights on the display screen came on and the graphics on the screen went blank. Machine ran fine and I still had the hydraulics but none of the switches available through the display panel were accessible including the attachment release.
I cycled the machine ignition several times with no success, the panel remained blank and warning lights lit. I suspected an electronics malfunction and started looking for a breaker or reset switch, first in the cab and then under the engine covers but found nothing. I put a call into my dealer to see if they had any ideas but got voicemail. It was right about lunchtime so they may have been on break.
I remembered the battery compartment and looked in there and discovered a factory battery disconnect switch. I shut it off for about 30 seconds and tried again and everything had returned to normal. About two hours later I got a call from the dealer where they said they were working with the factory to come up with a solution for me. I told him what I had done to correct it and he thanked me, said they will make a note of that for future reference.
This may or may not be a problem with other Cat equipment, or any brand for that matter and wanted to post in case any of you have a similar problem. I essentially "rebooted" the machine computer to clear the error. I'm hoping this is a fluke occurrence.
