Hello All
The coupling between the engine and the hydraulic pumps has let go. Part of the replacement procedure is to drain the hydraulic oil. Unfortunately the drain port on the hydraulic tank is right above the right track. Is there anyway to release the brake on the swing motor so I can manually rotate the top to a better location?
Regards
Phil
Regards
Phil
