Cat 308c CR
Elii
Nashville, TN
Does anyone know how to switch a 06 Cat 308C CR from a hammer to use a thumb?
The foot pedal is currently only pressurizing one side of the lines at the stick. From what I can tell, the other side looks to be plumbed as a return.
Thank you
digger_hunter
Massachusetts, USA
you need a 2 way spool with relief valves with proportional control solenoids or valves. I might have something for you on that but if the aux valve on their doesn't have it already it would need some modification on the main control valve side
Gtaia
New Zealand
Hi there just wondering if you got this sorted I’m also trying to convert the one way to 2 way to operate a tilt bucket
