Cat 316e no hydraulics
90plow
Northern New Jersey
My cat 316e was running fine when out of the blue the hydraulic functions all stopped.
so far we have:
Checked pilot pressure and it’s got pressure via the display
Checked and changed the hydraulic kill switch
Checked wire harnesses for cut wires
No luck on anything. Please help
John C.
Have you checked for codes on the monitor panel?
heymccall
Western Pennsylvania
Pilot solenoid coil failure?
And, yes, it will have a code.
Since you seem to know your way around the monitor (you said that you checked pilot pressure), A) retrieve the fault codes, and 2) verify computer input and output status, both analog and digital.
90plow
Northern New Jersey
90plow
Northern New Jersey
I went again today to run through and try to figure this out.
first picture is a new code I hadn’t seen before
Second is the ecm readings showing none which is weird
Third is another code.
Also the horn isn’t working
When I push thumb controls on the left hand side the motor bogs down slightly like it’s responding to aux pressure.
this photo shows power shift pressure as none
John C.
Logically you are looking at a disconnection in the harness or a faulty processor.
Time to pull some sheet metal and start diving in looking at harness couplers and components. You should also be able to narrow it down somewhat by checking component outputs in the monitor panel.
John C.
If the engine is running then I'm sure they should be reading on the monitor.
90plow
Northern New Jersey
So I’m deep diving on the web as much as possible. Pilot pump failure and pilot solenoid failure are solely hydraulic issues. My issue seems to be electrical since I have no read outs on certain items and the dead give away to me was the horn not working. Long day ahead of me tomorrow before I got to the cat dealer. Thanks guys
90plow
Northern New Jersey
Well sometimes the solution isn’t too bad. Found a bad fuel pump thanks to a blown fuse. Traced my problem
Back to the hydraulic lockout solenoid thanks to help from Nige. I swapped it with another solenoid and the machine moved just like normal. Thanks for the help guys keep at it.
