Gary Layton
2006 CAT 320CL sn PAB06638 Engine SN MAE05872 AR No. (arrangement) 2870092
While greasing the 320 yesterday I had the engine running. I heard a loud POP noise and a hissing release of pressure...and the engine rpms increased slightly. I immediately shut down the engine and looked for any obvious leaks...none were found. Re-started the engine and noticed an "E" in the a/c panel temperature display. The "E" appears when "AUT" is engaged for the a/c system. The a/c is not cooling now. It has been very good up til now in our S. Georgia hot days here. Is there an over-pressure release on the a/c system or did a hose likely burst?
I am in the process of reaching out for a service tech to come evaluate and repair. I found a video of CAT a/c repair and it looks daunting...remove the seat to access some of the system, belly plates for other parts. I accessed the ECM (ECU?) and copied out the codes...picture attached.
I won't be trying to fix it myself...no a/c experience...but if you have info you think might be useful I am all ears.
