Gary Layton
I am replacing my oil pan and started the process today. A few weeks ago I was cleaning out the belly area and had a hinged belly plate hanging down. I got distracted with another issue on the cat and forgot the hanging plate. When I slewed the cab the plate hit the track and mangled the plate as it drove it up into the oil pan area. The pan had a 3 inch long gash. No oil leaked out until I pulled the plate out...instant oil change.
I found a few interesting items in the pan. I would like your input on what you think these are.
First, I noticed triangular/cone shaped flakes of metal...very thin...maybe 6 flakes. They may be from the oil pan as a result of the plate trauma? Or are they ominous?
Second, there was a threaded bolt with a screw slot on one end and the other end was smooth.
Third, there was a metal "cup" that maybe the smooth end of the threaded bolt/rod fit into? I cannot see anything similar up in the piston/rod area.
Trying to figure out how to post multiple pictures.
