waynechute
Hey guys had a external leak at the swivel, seems it was the fitting for the small line that goes in below the larger 2 lines, had some extreme cold weather here and I suspect there was water around it and it froze damaging the fitting the line attaches to,it stripped the threads out, now I can not see into the swivel to see if its threads are damaged but I suspect they are, how do I remove the swivel so I can work on it better, never had one out, all I have is a parts book.Anyone ever run into this problem before, cat 320 bl 1999 serial #6cr02059.
thanks Wayne
thanks Wayne
