MFM Truck&Equipment
Hey guys, first post here. I am a independent repair company, looking for some input on this machine. I have a 328D cat excavator that is intermittently stalling. Scanned with cat ET. No active codes, only a few logged codes for unrelated stuff and all logged codes the last incident was 6 plus hours ago according to the time stamp. Started a few days according to the customer. Machine stalls throws no codes or events. And starts right back up after a key cycle. 1 out 10 times it will be a crank no start but starts after a key cycle or two. The only thing I have seen on cat et is the status bar shows no engine speed when it stalls. Under data when I crank the unit for 1-2 seconds the engine speed shows abnormal signal then shows proper speed and starts. I'm leaning towards a speed sensor issue. I have the double speed sensor under the HEUI pump coming tomorrow. Curious to know your thoughts, thanks. I have attached the serial number in the picture.
