Hi guys having trouble figuring out an issue with my 365C. When it's booming up with a full bucket and swinging it's losing rpm and pump pressure then it will run back up and drop again until it gets moving. Dropping to 1600 rpm then back to 1800 repeatedly also from 30,000 to 20,000 psi on both pumps with rpm drop and rise. The only fault code it has currently is for an engine speed sensor. I'm losing sleep over this thing.
