Cat 518 skidder dead engin need to tow to landing can’t get out of gear. Have auxiliary air to un lock brakes any suggestions.thanks
North Pole,Alaska
Have cat 518 log skidder with dead engin spun crank Bering.
need to tow up to landing, can’t get out of gear to role
have auxiliary air compressor to release the brake
still won’t role any suggestions, thanks
Coaldust
North of the 60
It should move. The torque converter should spin independently from the engine. It’s been a long time since I worked on a 518, but I’ve dragged them before. Maybe the crank shaft is catastrophic and the TC is jammed up. ?
Pull harder, She’ll come easy. That’s what I learned from the rigging crew.
North Pole,Alaska
Hi,
well I got the machine back to shop pulled engine rebuilding now.
but with the braking system how can I release the air brakes? Like on a big truck I can cage the brakes to unlock them. Any ideas thanks
Mike L
Texas
Self employed field mechanic
Can you unhook the discharge line from the compressor and hook shop air to it?
The scratches on the plate make it difficult to interpret, but going in via the transmission S/N 1ZC01901 led me to a machine Serial Number of 95U02184, built June 1988.
So you can either apply external air, cage the parking brake, or remove the axle shafts. See attached that covers all three.
  • Towing.pdf
