Cat 623G
Jim Irwin
Hi guys.
I am on the lookout for a 623G, and apart from the usual spin from CAT dealers, what are the good and bad points on the 623G?
Any info greatly appreciated.
Jim
DPete
Central Ca.
A 623 in any model is a very productive machine in most materials except slabby gumbo, rocks and blow sand. I have a pair neither are G's, one is an E that has been repowered with G parts. The tier 3 C15 may not have quite the grunt of the 3406 but power is adequate and fuel consumption is less. The other is a late F with the same scraper as the G. The only negatives I can think of is the elevator chain adjustment was changed from very simply raising the small roller to a hydraulic grease and shim affair which is fine but much more complicated with seals to go bad etc. The other is Cat went to a smaller diameter roller on the rolling floor, we all know a big wheel turns easier than a small one. They are a complicated machine and need to be looked after, we grease every day. I can't comment on the G's joy stick control someone else probably can. Good luck, machine prices are way down here in the US and it's a good time to buy if you have the work. DP
Cmark
Hi Cmark
Not sure what you mean by ' reworks published....'
Also known as a service letter. How Cat communicate to their dealers that some machines may develop a specific fault and what action the dealer can take to rectify the issue...
TD14A
Alberta, Canada
Oh, sure. Like a PIP ( Product Improvement ... something or other )
I like to check and make sure they're all up to snuff.
If you would like to discuss something specific, I left my email on a previous post.
