631G
I’m looking at a 2014 and a 2015 740B set of trucks at auction. Both have right at 7000hrs. They look great cosmetically. I’m working on getting permission to go pull oil samples and put a close eye to them.
Until then can I ask for some options on the trucks and what to look out for? For example a good friend of mine from college is PM on a new Hyundai plant moving several million cy of material and they’ve got something like 30 new 745’s and I’ve been told by him and my Komatsu dealer that these newer trucks all have transmission issues out the wazoo. Friend says that a new cat truck they’ve got has already dropped a transmission with less than 1500 hrs. The sales rep with Komatsu says it’s to the point that some of the local large outfits are dropping Cat and buying fleets HM400’s instead of 740’&745’s. He claims it’s because Cat put a bigger engine in them and the transmission cannot hold it together.
What are you guys seeing? Are the transmission issue only isolated to the newer units? When I was at Kiewit, I worked on a reservoir project in 2012/13 that had a herd of them when they were new but not in my group and then later on in 2018 I had some 740B’s I was responsible for and they all ran well except for one instance where the front axle was the only one pulling and it turned out to be something with a clutch in the transfer case as I recall. (Not too sure if I’ve got that recalled correctly or not.) Should I be leery of these 2? As I recall these should only be 50% of their first life until rebuild is needed.
