werk241
Loader Serial # 80U6085
Engine: 3204PC
Engine Serial #45V15990
Arrangement: 4N303
I am not sure of the year.
It is a wheel loader.
Here is my problem! I ran the loader out of fuel, filled it back up to the top. Tried starting it after hooking truck to starter and letting it turn over forever it finally cranked.
It will rev up full throttle but as soon as you let of the gas it dies.
I bled all of the lines, pulled the screen that is inline with the push primer it was full of trash.
also have put two new fuel filters on it.
All loader will do is run full throttle with little spit and sputter, still if you let off of gas it totally dies,
Also when full throttle I try and run the loader and when it is put into 1st gear it will barely go, 2nd gear bogs down even more and unless I am on a down slope will it let me go and stay running into third gear.
I do not know what else to try! It is useless due to power loss the way it is now.
Any help would be a life saver? Thanks to all!
Engine: 3204PC
Arrangement: 4N303
