The s/n tag is missing from the lower dash. On the left side of the engine block I found 86J455. That is all I can find that resembles a s/n. This machine is a recent purchase as a bit of a project. When I went and looked at the machine I was not able to actually work the machine because of it's location. When I got it home I found out then when it gets warmed up that first gear forward and first gear reverse gradually fade away the warmer it gets. I was able to borrow a service manual from a buddy. I checked pressure on top of the transmission filter. I had basically no pressure in 1st F/R. 2nd and 3rd were around 275 psi at low idle. I took the cover off the transmission. Started the machine and there was some oil oozing out the top of the control valve. I had the linkage unhooked and when I reached down and put it in 1st gear oil shot straight up out of the control valve. So I pulled the control valve out and have it on the bench. I don't have a parts manual yet. Is there a rebuild kit of some sort for the control valve or do I just have to buy the pieces individually? It looks like 86J is a good prefix for this machine but I feel like there should be at least 1 more digit? The service manual that I borrowed is for 86J1992 and up and appears not to be 100% complete. Any help would be greatly appreciated. Thanks
