JD8875
Moving the lower pivot forward before you bend/break an adjustment shaft is much easier. I was in the same boat last summer. Getting the bolts out of the master link is the hardest part of replacing the adjustment shaft. The bolts holding the pivot mounts to the track frame were no peach either. I suggest getting the torch bottles filled so you have plenty of heat. Then buy new bolts to put back along with a big can of anti seize. You will know immediately if the last guy anti seized the bolts or if he just threw them in the holes. I moved my pivot mounts forward using two ratchet boomers and short chains off the bucket teeth once they were unbolted, it went pretty smooth.
Good luck
John
Good luck
John
