Iron Dinosaur
Machine has existing problems with right side drive being weak or out, but it always engaged into gear and would move in forward and reverse, mostly under the power of the left side. Months ago, I adjusted the foot pedals according to the service manual, they were way out of spec. Since the pedal work, the tractor will go forward but not reverse. Could that be as simple as the brake band(s) are stuck? I did make some mistakes initially with the pedal settings but eventually got it right, could have cranked too much on the brake setting bolt, but I'm not sure. Nothing else significant has been changed. The machine does sit for several months at a time without being touched, also not sure if that adversely affects anything.
