Iron Dinosaur - Post some photos of the track chain and final drive, so we can ID what you've got, and what you're facing.
The master pin is usually identified by a sizeable but shallow hole drilled into it - unless you have the "alligator style" bolted master link that is a later design.
You can see the zig-zag pattern in the links where they join, if you have this style.
The alligator style master link removes the need to drive out a master pin.
Master pins can be driven out with a large sledgehammer and drift, but you need to be pretty fit, and also have a couple of helpers!
The important part of setting up for master pin driving out with a sledgehammer is to ensure the track is solidly blocked, so that the impact of hammer hits is not absorbed by track deflection.
Many people claim the best position for hammering out a master pin is at the idler - I always found a better hammer-driving position was at the sprocket - because the sprocket doesn't deflect as much as the idler. You still need to support the master links at the rear with a solid support or bucking bar.
You may be able to hire a portable track pin press in your area if you're not too remote. You usually need a small crane to support the portable track pin press, they aren't exactly a lightweight device!
First step (besides photos) is to fully clean down the track frame area (remove all track cover guards, shovel off all dirt, and pressure wash) - and allow enough working area around the tractor to have room for the track to come off and spread out.
If you have a tractor front end loader or something similar, these can also be useful to assist in track removal and replacement.
You'll need lifting equipment or a helper to remove the heavy final drive housing. An impact wrench speeds up bolt removal on the housing bolts.
Once the track is off, the track frame needs to be unbolted at the outer hub and at the cap on the inner track frame diagonal brace bearing - and the tractor must then be jacked up and solidly blocked so the final drive can come off
The job is not rocket science, it's just that you have to familiarise yourself with the procedures and ensure you have at least one helper, because everything is heavy.
A 955K master pin shouldn't need any more than about 40 - 50 tons of pressure to remove, unless it is exceptionally corroded.
A S/N of 85J3811 makes your tractor a 1971 model.
Explore WTC Machinery's 100-ton excavator & bulldozer track pin press. Ideal for Caterpillar D9, Komatsu PC600 & more. Safe, efficient & versatile. Request Quote
www.wtcmachinery.com
