Did that the reverse ones are new and one forward one is new so I swapped with new one and also removed brake control solenoid it was grungy cleaned it up tested it and it acts kinda sticky like sometimes doesn’t open all way but most time as good reinstalled it and still no change in speedlets try changing one of the reverse solenoids with the override solenoid careful though it might screw up reverse tracking
Well I bought at auction and just now found out through cat who owned it before I can’t get in contact with him to see what he knows I’m guessing when cat told him needed two pumps he just sold this was after they told him new ecm and didn’t fix problem so guessing he just cut his losses ! I agree I think it’s something I’m just missing because it has a ton of power up to 2mph will show mountain of dirt and will spin tracks easy if you Barry bucket in ground so to me it’s hard imagine pumps are weakI'm going to have to thing about this for a while Every thing you check seems right even signal to motors is pretty close it's a couple pounds shy of what it should be but it should be at least be very close to min angle on motors The thing that bothers me is if it's a motor problem they would both have to have the same problem. This seems more of a control problem. because it effects both sides. Was the guy you bought it off of the first owner? Did he mention about it being slow? This is going to turn out to be something stupid like someone was trying to slow it down to save the track!
Ok took both lines off at motor coming from sensors for signal pressure and found nothing obstructing them then went in sub 26and 27 for signal pressure in 26 pressure was at 110 high idle park and raised to 1710 full forward and 1800 full reverseThis is going to sound dumb but down on the motors there are sensors to read signal pressure to motors check fittings between sensors and motor for being plugged
Yes just been studying that exact thing thinking might try to do that procedure start to finish and see what results I getThere is a way to set them look in stuff Nige sent
Hey Cmark I got speed readings figured out just crawled under and began adjusting sensors in from what book said was right went half turn at time and at 1 1/2 turns from bull gear I’ve now getting speed reading on both tracksBack in post #116, you said pilot pressure at max fwd and rev was 200psi. This is about right. I have a feeling it may be just the motors that aren't destroking. I ask again, does it look like the motor adjustments have been tampered with?
Whatever the answer though, we still need to be getting a reading from the speed sensors to adjust things properly.
That's good. Probably a bit close for comfort but should be OK for troubleshooting. You can reset them to 3 turns when you're finished.Hey Cmark I got speed readings figured out just crawled under and began adjusting sensors in from what book said was right went half turn at time and at 1 1/2 turns from bull gear I’ve now getting speed reading on both tracks
Yes I have plugs but no access to ETTo adjust the motors on the machine, you will need some way to monitor track speed when you are working underneath it. Do you have access to ET?
You will also need ORFS blanking plugs for the two signal hoses.
