Hey Guys,
We have been making steady progress with the two 977Ls that we bought for scrap. We got the one motor free, put the head on from the other machine with the bad bottom end, and actually got it started. Seems to run pretty well.
Immediately it started pouring fluid out of the TC that was white and milky. It looked like from the output flange seal.
From what I can tell or read it sounds like this is a result of it being over full because the engine coolant to trans fluid heat exchanger on the engine is leaking coolant into the trans fluid? Luckily I have a K machine motor and TC on a trailer in my driveway with some pictures attached here. I am pointing at the heat exchanger in question. You could clearly see with the layout of the hoses where the fluid goes from the TC through the heat exchanger up to the oil cooler next to the radiator and then back.
Just wanted to get some thoughts and make sure I am on the right path? Also, why would this happen? Does the heat exchanger corrode and start to leak or is there seals in there or something that goes bad?
Second, is this possibly why it is leaking so bad?
Thanks!!!
Tyler
Thanks!!!
Tyler
