EdB
You seem to be very knowledgeable about this Caterpillar equipment. Especially this model. Our family farm have around 10+ Caterpillars on our ranch, from D-3's to D-8s, so we have worked on Caterpillars quite a bit. Until a week ago all of out Cat's have all had metal tracks but we recently purchased a 1988 Caterpillar Challenger 65 from a neighbor. This machine has 10,535 hrs on it and has been maintained well (we are friends with our neighbor and know how well they treat/maintain their equipment) so we were comfortable buying it. We needed a bigger machine to pull a 42' hoe drill we recently purchased to plant roughly 2,000 acres of spring wheat in our dryland ground. This machine hasn't been in operation for 2 years since our neighbor switched from raising their own onions for their processing shed to instead contracting out ALL of the onions they use from neighboring farmers. They have had this Cat in their operation for 6+ years and they only used it to pull a 24' groundhog (basically a schmyzer roller followed by 2 rows of triple k shanks then a leveling bar and then one more schmyzer roller). To make a long story short we got it out in the field to pull some harrows and we have problems with it turning. So we started simple and cheap by changing the filter. After changing the filter it turned EXTREMELY well, it would turn on a dime. Unfortunately after running it for 3 hours it quit turning sharp and would hardly turn at all. I shut it down and tried it the following morning and it was turning really well again for the first couple hours and gradually it would turn less and less sharp as time progressed until it wouldn't turn at all! I am wondering if you could email me at
[email protected] and then maybe we can exchange phone numbers if you are willing and have time because I would really appreciate some advice asap because I need to get this problem fixed ASAP and as cheap as possible so we can get all our spring wheat in! As you know farming is all about timing, especially when planting spring wheat on dryland ground!
Thanks in advance! I really hope to hear from you!
Galen
