Hello all, I recently posted in search for a few needed parts for a 49 D4 mainly the main clutch lever which I now have. Its been sitting approx 12 years. So my issue is, the main motor is locked up. Can't turn it by spinning the radiator fan at all. The main clutch won't engage and is currently stuck in neutral. It appears to move just a touch when I move the lever back and fourth but just wont move. I did pour some oil in all the cylinders through the injectors. The lower crankshaft compartment looks great when I removed the side inspection panel. I disconnected the interlock rod to see if that would make a difference and it didn't.
Any thoughts and feedback will be greatly appreciated. My thoughts were if I could engage the clutch could I then engage the starter motor clutch and put a 2 1/4 wrench on the pony motor flywheel pulley and see if it could move the main engine to free it up.
Jeff
Jeff
