CAT D6B Walking out of tracks
Mulla1
I have a D6B which keeps walking out of either one track or the other when operating sideways on a slope. I have overhaulled the tensioners and reset the tension as per the maintenence manual but it continues to happen. Did this machine have track guards and if they are missing would it add to the problem ?
Thanks for any suggestions.
OzDozer
Perth, Western Australia.
Semi-Retired ..
Track roller lower guards do assist with keeping the track on - but you need to check track frame alignment and idler alignment.
The idler can get "cocked" in the track frame via a bent idler pushrod. This happens when operators run into big rocks or stumps or big logs at speed, the impact on the idler bends the pushrod.
Then you need to check track frame alignment. This is easily enough done by running a tape across the back and front of the tracks, measuring C to C, while the tractor is on level ground.
Any more than about 12-15mm (1/2" - 5/8") difference in toe-out will increase track wear and facilitate tracks walking off.
The track frames get out of alignment via worn outer sprocket bearings (bushings), bent diagonal braces, worn diagonal brace (inner) bearings - and even bent track frames! Yes, you would be amazed at how much track frames can get distorted with bends and buckles.
Alignment of carrier rollers is important, too. To align the carrier rollers, idler and sprocket, you hold a string line across the top of all those components when the track is off.
Finally, idler guides and wear plates must be kept in good condition, as any wear in these areas puts the idler out of alignment with the rest of the track and encourages tracks to walk off when conditions become adverse, such as sideways on steep slopes.
What shape are the tracks themselves in? Worn tracks get snaky which makes come off easier. I've heard adjusting the tracks a little tighter helps when working on slopes. Maybe some plates could be welded or bolted on the track frames to help keep the tracks on similar to rock guards but wouldn't need to be full length.
Mulla1
Thanks OzDozer, a very good and well explained list of checks to do. Where are the idler guides and wear plates located. Are they bolted or welded on the inside or outside of the idler ? I think with the age of the machine then these may be missing ! I'll check when I go back to work on it.
Welder Dave thanks and yes the tracks, idlers and sprockets are all in good shape. If all else fails I'll take some advice and weld track guides on.
OzDozer
Semi-Retired ..
I need a tractor serial number, and even a photo or two of the idlers, to ensure I give you correct information on the style of idler guides your tractor has, because there were quite a few idler design changes over the life of the D6B.
Mulla1
Sorry OZDozer, late in getting back to you. The serial number is 37A1939 if this helps.
i'll get photos next when up at the dozer
