Need some advice on this one. While cleaning the dozer I noticed the track spring has 1 coil sheared in half. Track is still tight and adjusts just fine. I only plan to use this machine 100-200hrs per year. It’s going in the shop to get new sprockets and replace a missing roller on the same side. I know replacing the spring is a huge job. Should I have it replaced while it’s in the shop or just operate as is since there are no issues with the track loosening.
Kinda hard to see in the pics but it is a diagonal shear all the way through the coil.
