I first posted this in a different forum - probably the wrong one, trying here instead.
I bought a CAT dozer blade attachment (model# 231-5275) that is missing the wiring harness. Seller said one of his cows ate it. I pulled the cover off the solenoids and attached new wires to what was remaining. There are 2 solenoids, each with 2 wires. I need help understanding how the two solenoids should be wired to control blade tilt and angle. Each solenoid makes a "click" sound when wired to 12 volts.
To keep this message simple, I won't bore everyone with what I've tried to date. If someone can tell me or provide a copy of the wiring diagram and or hydraulic schematic for this attachment I would be greatly appreciative.
I will be using this on my Bobcat T200 skid steer that has a 14 pin connector, I am familiar with what each pin does, that's not the issue.
Here's a picture of the solenoids, if it helps...
![Dozer solenoids.jpg Dozer solenoids.jpg](https://www.heavyequipmentforums.com/data/attachments/181/181723-20c3f114211751a83eea947ae065212d.jpg)
