Columbo
Hi all, two questions regarding the bucket (and thumb) on my Cat 311b excavator (s/n 08GR00401). First, there is about 10mm of space between the bucket ears and the side of the stick. Is this normal and permissible or should I get a stack of shims to center the stick between the ears?
Second, the previous owner added a mechanical thumb. Since it’s a generic thumb it does not mesh with the bucket teeth. The thumb tines hit the middle tooth and if you’re not careful the thumb has enough play to shift slightly to allow the teeth to slide alongside the tines. The makes it difficult to pick up small rocks, brush, etc and probably isn’t the best on the thumb mounts. I’ve tried to come up with a solution for this but short of cutting the tines off the thumb and re-welding them in a different spacing I could not come up with much. Possibly a bar welded across the end of all the tines for the bucket to close against? Or just learn to live with it, lol? Any opinions or ideas are appreciated!
