CAT IT18B ( 1990 ) AIR VALVE QUESTION
TEX32
Sault Ste Marie, ONT, Canada
Owner, Technician @ INTEGRITY HEAVY REPAIR INC.
Afternoon boys. Recently purchased an IT18B wheel loader to flip. A little elbow grease and some repairs...
Anywho, I have a question regarding an air valve located in the RH corner front of the operator compartment. Just forward of the joystick tower. I do NOT have an operators manual for this unit, and I can't seem to figure out what this control is for.
I "believe" that it "might" be for a transmission function, but I am unsure to be honest. The sticker has been previously half torn off. This is a flapper air valve, much like a diff lock valve on a highway truck.
Any help would be great!
Thanks
Tex
lantraxco
Elsewhen
Not the quick coupler switch is it? I've forgotten everything I ever knew about those machines.....
Thanks
Tex
Does it look like this..?
TEX32
Nige, you beautiful man! Been a while. How are you?
Yes, just like that. Is it a neutralizer? And if so, why would you require this function, when the machine has a neutralizer pedal? ( towing? )
Good thanks Tex. Yourself.?
Your switch is a disconnect for the transmission neutralizer function on the left pedal.
As you know usually the only difference between the left & right brake pedals is that the left one also disconnects the transmission - the neutralizer function.
This switch is a way of being able to have the left pedal behave exactly the same as the right one (i.e. the transmission is not neutralized when you press it). For an IT the ability to "inch" a load into position is pretty useful. With this system the right-foot throttle pedal can be used with the left pedal functioning as purely a brake so that the operator doesn't have to try to squeeze both his Size 14's to the right side of the steerting column.
I dunno if the switch in your machine is algined side-to-side or fore-and-aft.
If it is side-to-side, the neutralizer should be disconnected when the switch lever is facing towards the operator.
If it is fore-and-aft, the neutralizer should be disconnected when the switch lever is facing towards the windshield.
I think the decal should look like this ........... can't find a Part Number for it anywhere.
  • 9V-8926.pdf
TEX32
Hey, no foolin. PM me your address and I'll call a local "1-800-Dial-A-Beer" company and have them drop off a 6 pack and a pizza pie to you!
