cuttin edge
Watched a video the other day of a guy installing a conversion kit on a Duramax to fit a CAT IR-1807 oil filter. Knowing how expensive Cat can be, would it be worth it' and what would the benefits be?
Because they can. Goes with the flat brim hats
We're not discussing backwards caps, we're talking about flat bills. You know, white boy gangsta things.Ball caps backwards is like fat people in spandex. Should be some kind of law against it. Welders caps are designed to be worn backwards and sideways to protect from sparks. Ball caps not so much. Have seen a couple welders use ball caps for welding. Terrible idea especially if they have nylon in them and/or a nylon adjuster. If something bad happens the nylon can melt and weld to your skin.
That hat ain’t got nothing on this one…. New trend for the young kids.View attachment 275193 View attachment 275194
Seems the higher it's turned up the stupider the person looks. Probably has the belt on his pants about a foot below his waist too. I was in a mall and saw a kid like that. You just want to tell him how bloody ridiculous he looks. You're also kind of hoping his pants fall right down and everybody's looking at him trying to pull his pants up with his belt still firmly tightened.View attachment 275193 View attachment 275194
My 2.7 Eco boost has a cartridge oil filter but it's up higher. For me it's much more convenient to just go to a quick lube. The one I go to isn't a big franchise and quite a bit cheaper. Quite a few years ago I went to a franchise quick lube because I had a coupon for a free oil change. While the oil was draining another person takes the intake boot off, without asking and it's a little black so says I should get the intake cleaned... for about $16. I declined. Then they tried to charge me for an extra litre of oil at about $5. I said the coupon has no limit of 4 litre's on it only that diesel is extra. Then they said, "well we'll let it go this time". That's a pretty straight forward case of false advertising. I knew that because I heard about a lawyer getting a car wash coupon and then getting another coupon after his car was washed. He went home and brought his wife's car back. The car wash tried to say the coupons were limited to 1 car per customer. Nope, only if it specifically mentions conditions on the coupon. It was a little ironic a lawyer was that cheap but he was right.I'm pretty annoyed with the whole cartridge filter thing. Started with the 7.3 I think. Except all the antiques from the 60s.
This is a bit confusing. Reading it says there is more mess with Cat.I hate filter cartridges on equipment. More mess the way Cat does it vs a simple spin on.
I hate FLOOR sweep, drain pans under anything that has fluid. Last time I bought floor sweep 5 years ago
