partsandservice
Looking to diagnose the issue with first gear slippage before removing the transmission. When attempting to operate machine in first gear , it will throw the slippage code and go into limp mode with only second gear. It also has output speed sensor codes. I need to know which two modulated valves corresponds to each gear. Each valve has a pressure check port. We will get to all the codes but first we will deal with the transmission. Thanks in advance. The picture shows the trans codes as inactive but will become active under operation this picture was taken key on engine off
966M KJP
966M KJP
