Caterpillar excavator 320E LRR moving slow
idss
Antigua
I am working on a caterpillar excavator 320E LRR serial number TFX00784 , The machine is moving slow, all attachments including
tracks, there is a Alarm in red SERVICE REQUIRED in the display, dose any know what this means and how to reset it ?
8V71
Fresno CA
Machine could be in a derate,need to look for any active error or event codes in monitor. With that action alarm there should be an event code go into the monitor service diagnostics
idss
Antigua
all shows unknown ECM , Current below normal, anyone can tell me where to get the service manual?
ok there are codes 3633-5,3576-5, 3575-5, 2103-5,581-5
Are those five Codes Active or Logged.?
The monitor display should differentiate between the two types of Code.
Once you confirm that I can post up some troubleshooting procedures.
Assuming they are all Active, they are as follows: -
0581-5 - Power Shift solenoid.
2103-5 - Boom circuit regeneration solenoid.
3575-5 - Pump #1 flow limitation solenoid.
3576-5 - Pump #2 flow limitation solenoid.
3633-5 - Swing Priority solenoid.
The FMI 05 for all of them relates to "Current Below Normal. FMI 05 occurs when the current through the identified circuit is below the valid range. FMI 05 most often relates to a driver circuit.
8V71
Fresno CA
All those codes are from the machine ECM MID299. They are all related to the solenoid bank. J2 connector on the machine ECM pin #19 & #22 are returns for those Solenoids. Two of the Solenoid returns in question use wire 739-yellow pin22 and 2 use 968-orange pin19. Look the harness over Between machine, ECM, and solenoids for something obvious to start with. Are all the codes active? Active codes will have an X stored codes will have a dash
Check your messages. You should have a schematic.
Attached the tropubleshooting procedure. As @8V71 said above you need to be looking for something common to some if not all of the Codes. Wires in the same harness, routed trhough the same connector, etc, etc.
  • MID299 CID0581 FMI05.pdf
  • MID299 CID2103 FMI05.pdf
  • MID299 CID3575 FMI05.pdf
  • MID299 CID3576 FMI05.pdf
I have the same problem and codes mentioned above , what was the issue
If you have the exact same Codes Active as the OP I would suggest that you carry out the troubleshooting procedure for each one that were attached above. If you want a complete electrical schematic please post a machine Serial Number.
idss
Antigua
Thanks for all the help, the problem was the J2 connection, there was corrosion from salt water, the machine working like a charm now.
