That is the electronics doing their job to protect the engine from damage.i saw that when i get that warning, the engine starts loosing power under heavy load.
That would have been interesting information to include in your OP so as not to send us off on a wild goose chase......However, when I turn the key at the beginning and even before starting, à warning pops up saying that the Inlet air heater is ON.
I will look into this. What about testing the selnoid and sensor? Do you know their locations in that machine please? And how to test them? I have the tester....That would have been interesting information to include in your OP so as not to send us off on a wild goose chase......
Have you looked in the Monitor menus for any Diagnostic Codes, even taken a look at the temperatures registered by the various sensors.? e.g. ambient air, coolant, air intake temp, etc. If you are not familiar with the system, see the attachment.
If you need a password to get into certain sections of the monitor 9992 should work, but TBH to get temp reading it should be in the basic operatore menu.
I tried looking at the monitor, there are no diagnostic code up there. Other than the warning I get. I attached the screenshot of the coolant temperature and the warning that the intake heater is on even before starting the engineering. I also went and disconnected the wire feeding the heater from the solenoid, but it still shows that the intake hair heater is ON. I'm quite lost here. Do you have any suggestions please? Also, I this I should replace the temperature sensor. Is there a way to check it before ordering it?That would have been interesting information to include in your OP so as not to send us off on a wild goose chase......
Kindly look at my latest post and let me know if yoh have any suggestions.The inlet heater is supposed to come on when you start the engine cold. Its on a timer and should shut off after a few seconds. If it comes on when the engine is warm and the ambient temperatures are warm then there might be an issue.
I would start with checking to see if the heater is powered up when you get that warning. If there's no power to the heater then your issue is something else.
Do you have an infra-red heat gun.? First thing you should do is to shoot the temperature of the housing where the sensor is mounted. Is it reading the same (or close to) temperature that you see on the Monitor.?Also, I this I should replace the temperature sensor. Is there a way to check it before ordering it?
So the gauge on the monitor (which I assume is fed from the sensor) is reading 34C.? Based on that why would you even consider replacing the sensor. TBH the gauge reading really needs confirming with a heat gun before moving forward.I don't have with me now. But the temperature 34 C degrees looks reasonable.
The picture showing the whole diagram is not clear, I could locate the connector you are referring to. Could you please send a clearer Picture please?So the gauge on the monitor (which I assume is fed from the sensor) is reading 34C.? Based on that why would you even consider replacing the sensor. TBH the gauge reading really needs confirming with a heat gun before moving forward.
Have you tried unplugging the 2-pin connector #16 at the air intake heater relay.?
View attachment 314277View attachment 314278
That's main battery power to the relay. Not a good idea to disconnect that.BTW, what I have disconnected is the the one marked in red.
Is the message on the Monitor still there.?What would be the next step then?
