Champion 710A
Adam Walden
I have a champion 710A in my shop, it will not take any gear. I pulled the strainer in the trans, it didn't have clutch material or anything that would lead me to believe I needed tu pull the trans, the owner said it would move when he parked it a couple years ago. I checked the pressures on the trans pump, they were just a little under spec at operating temp so I changed the pump, that didn't help, any suggestions would be greatly appreciated,
DB2
Winnipeg MB Canada
Yes a 9150 was a powershift with 3 speeds and a manual high low. Depends on the year of the machine. The 8400 came out in around 1985.
DB2
Winnipeg MB Canada
First thing I would check is if the drive shaft between the clutch and transmission stops spinning when trying to start moving. Could be a clutch issue as well.
Don't think there'd be a declutch but need to figure out what transmission you have. Power shift is too vague. If it's an 8400 it wasn't uncommon for the solenoids to go out or act up from what I've read.
