Southbus
Cummins 6ct 8.3 12 valve , 173hp
The Story of this old Six cee tee
This engine ran erratically, cylinder 6 was dead and always smoked heavily when accelerating.
Observations:
When disassembling, note that the liners had cavitation problems, especially that of cylinder 6.
Work
I put new liners, new piston rings, new metal connecting rod and bench (STD), these had very little wear but taking advantage of the instance I decided to change them. The injectors were restored at a diesel injection company and the cylinder head was also overhauled and they put new guides and seals along with grinding the valve seats.
The long-awaited day.
Yesterday I started the engine and it has a more even sound and all the cylinders work although, after an hour of operation I can observe two situations.
1- When accelerating quickly, black smoke is produced, In practice this black smoke is seen every time I change gears.
2- The idle is at 730 Rpm and I feel that there is some kind of oscillation perhaps caused because at this level of revolutions all the cylinders do not work evenly.
Obviously I cleaned all the fuel lines, and I put in new filters.
The only thing that did not receive service was the injection pump (Bosch)
I don't know how to check if the timming is at 11 ° as the manual says.
What do you think about these anomalies in this newly tuned engine?
I take this opportunity to thank everyone who advised me on this my first engine adjustment and it has really been gratifying to revive this little monster.
Cheers!
Cesar
Observations:
Work
Cheers!
Cesar
