I have a 1970s 24-ton JCB 808 excavator that gets daily work. It’s a great machine for use around my farm but it has reduced hydraulic power at almost every function - it struggles to turn, the boom and dipper aren’t as strong as they should be, and it struggles to slew on sloping ground.
The hydraulic pump is generating good pressure, every relief valve on the machine is activating right on original spec. The turbo Perkins 6.354 is running like a dream and never shows signs of being under powered. The hydraulic oil is new, the tank is full, it’s ISO 68, and the oil temperature stays under 55 degrees celsius.
I’d like to improve the hydraulic performance as much as possible and am looking for the best places to start looking. Given pump pressure and engine horsepower are good and relief valves are operating at spec, where are the next likely sources of power loss on a machine of this type and age?
