I have a Clark C20 forklift serial number C2038E1238 from Oct 1958. The forklift is not currently starting and I am hoping that someone can help me figure out why. Thanks in advance.
A little history. I recently purchased it and when I got it, it was Running but not running very well. The engine had a strong smell of leaking propane, and needed the starter replaced. I have since had the starter rebuilt and it runs strong now. I have also replaced the fuel lock off, fuel filter, and cleaned the vaporizer. When I had the vaporizer open I checked for issues with the diaphragm and anything else I could see but everything looked good. I have not touched the carb since the tuck last ran.
The issue I’m currently having is that the forklift starter is running and in gauging the fly wheel but the engine is not even attempting to start. I am assuming that the engine is not getting any fuel but I do not know why. I have checked and the fuel lock off solenoid is engaging when I turn the key. I know that fuel in making all the way to the vaporizer as soap bubbles were showing up there until I tightened things down better. I have checked and the distributor cap is getting power, so I should have spark. Any direction that I should look would help a lot.
Here is a short video of me attempting to start the forklift:
Another question I have is, how do I get the engine cover up and off the engine without it hitting the steering wheel?
Regards. David
Regards. David
