COMING SOON.....New Product Introduction THIS SUMMER Mustang 1050RT
apetad
Leander, Texas
Compact Construction Equipment Sales
Standard Equipment
Yanmar Tier IV / Stage 3B Naturally Aspirated Diesel Engine
31.8 Net hp (23.7 kW) @ 2,800 rpm
34.7 Gross hp (25.5 kW) @ 2,800 rpm
Load capacity1,050 lbs. (
476 kg) @ 35% tipping capacity
Bucket pin height 109 in. (2,769 mm)
Standard auxiliary hydraulic flow 14.5 gpm (55.0 L/min)
Tags
Connecticut
I imagine with dirt, mud,rocks, and ice getting wedged between the sprocket and the track frame that it causes premature wear on the sprocket, and if someone doesn't clean the track frame after running in muddy conditions and it freezes overnight I can't imagine it being too much fun to get the machine moving in the morning. I think pretty much all CTLs undercarriages are designed this way, probably to keep the height of the track as low as possible...
KSSS
Idaho
excavation
One time we didn't clean the undercarriage out on a CTL on a Friday just before Winter hit, temps went subzero over the weekend. Machine was stuck to ground, and the mud had froze the undercarriage into a block of solid mud. I had to haul down a diesel fired infared heater and thaw each side of the machine, took hours. If the guy that leaves the machine like that, has to unstick it, tends to solve the issue from happening again.
John C.
They could have put in an extra roller and extended the rear idler back some to give clearance on the sprocket. I can see no end of tree limbs and roots winding up in that notch between the track frame and sprocket. Also in the photo there is little clearance between the front of the track frame and the track as it goes into the front idler. Might need to install a top roller there for clearance.
I don't know if its me or what but all this little stuff strikes me as a commodity. All brands are pretty much the same except for the electronics package. It's like buying a pickup. None are really any better or worse. They all will do the job. They all have their shortcomings. Reminds me of the cartoon movie "Cars" and the stampede.
245dlc
Heavy Equipment Operator
Didn't Gehl and Mustang have a CTL with some sort of self-tensioning undercarriage that was just released a couple years ago? I know I've seen more than a few on auction websites and related used equipment dealers with quite low hours, makes me wonder if they held up as well as was promised? The area I live in has some of the most challenging ground conditions for any CTL wet, freeze and thaw, thaw and freeze, cold cold cold, heavy clay gumbo, silt, mud, mud, mud. Lol Hence why the ASV style undercarriage has always been a bit of a failure here if used for earthmoving and grading work.
apetad
Leander, Texas
YES, This model DOES HAVE SELF TENSIONING TRACK / Uses pilot pressure and a cylinder inside the track frame to set the tension, ALSO you can flip a switch and it sucks the front idler in for changing the track!
apetad
Leander, Texas
Moving the rear bottom roller further rearward would reduce the "Wrap" around the drive sprocket, IE less contact with sprocket teeth fewer mandrels contacting fewer of the sprocket teeth
apetad
Leander, Texas
I wonder if detensioning the track with the switch overnight would help reduce the freezing problem???
John C.
Adding room on the back of the track frame was done on Cat 527 tracked log skidders with no measurable change in wear patterns. How many teeth do you think have to be engaged with the track in order for the machine to move?
crane operator
sw missouri
how wide is it?
I was kind of wondering that too. Its only 34 hp so I wouldn't think it was very big. I think some manufacturers have really downsized the hp on some machines trying to get under tier regulations?
Are you going to be changing tracks on it that often- that it needs to be powered track tensioner? Be real handy to accidentally hit that button in a mudhole and flop a track. Because you know it would only happen in a mudhole.
I don't think detensioning the track would help with the freezing. I've had to load up a bobcat track machine and haul it into a heated shop. Wet mud in a track machine and a hard freeze overnight is a big pain. They can also pack up with snow and become a frozen block of ice.
KSSS
Idaho
excavation
I have never been that convinced that the auto tensioning was that big of deal, the ability to retract in order to change out tracks is a cool feature but I think I like most people get 1000 hours or so out of a set of tracks. I never keep them long enough to have to replace two sets of tracks on the same machine. I don't have detracking issues so it is a feature that for me has limited appeal as well. I have never had a machine freeze due to ice and snow to the point it cant move, they do of course freeze but the machine is never locked up due to the ice. The frozen mud like I mentioned already completely different story, locked up like a drum. I don't think the auto tensioning is going to save you from that situation either.
f311fr1
Middle TN
The Terex 30 size machines are 4 foot wide and will fit between houses with 5 foot set backs. We use ours a lot in Nashville.
apetad
Leander, Texas
The detensioning switch is inside the engine compartment
apetad
Leander, Texas
It's 54" wide, I wish it could get down to 48" but it can't,
apetad
Leander, Texas
Thanks for the info! I think the main reason is so that you do not have to use a grease gun to tension up the track, AND keeps it at the proper tension regardless of whether it has mud packed between the sprocket, rollers and the track.
