Good Morning, So I take it to be push of a button in the cab electronics to select the attachment for use and that will tell that valve which way to function. I know my Mini (Takeuchi TB240) has interior screen selection......so bottomline, your drawing here would not be a manual switch on the operator at that valve body, correct?Good day
The three way selector valve gives the choice of hammer (One direction) or grab -thumb (two way direction)
See attached its at the arrow "A"
Kind regards
Uffex
Sounds great, the grappple is just pin on thumb.I'll pull up the line card in the morning, we'll go through it. If it has grapple, odds are, bi-directional. Unless its just some pin on thumb. . We'll see
I just watched the video the owner sent me and I screen shot that section and I see those parts...Yay! If all is good, then I may have gotten lucky.Good day
The attached surfaced while I was looking for something else.
I'm feeling extra good about this machine with all the information you all are providing me ...I'm excited and working transportation now!!! Will keep you posted and I'm sure will be asking more questions after I receive it. I look forward to finding that filter you are referring too and seeing what the oil looks like inside!!If that's your machine, you lucked out. That valve to the right of the boom foot. That's your 3-way... valve. Depending on hammer or shear. In hammer the return oil goes direct to tank return filter. In shear oil goes to and from the MCV. That's the ideal set-up.
When you receive the machine. The first thing you want to do is vent the tank pressure and spin down the case drain filter. Its a short, wide spin on filter in the pump room. Pour out the oil in a clean bucket. Check it for golden glitter. If there isn't any, you're on top of the world.
Thx Sir!Good day
Extra information as promised.
Kind regards
Uffex
Uffex,Good day
Kind regards
Uffex
So just regular old prestone green from Walmart or Auto Parts store? Do you have any idea about that red warning light?That's gonna be regular old ethylene glycol, green coolant.
Looks like the previous owner had red in it....That's gonna be regular old ethylene glycol, green coolant.
Just keep like with like. If it's red, stick with red.Don't fill it up to the top, just shut off the light. There's no separate expansion tank, so if you top off, you'll have a couple gallons on the ground when it warms up
Are you sure as i thought the coolant light would be the light right adjacent to the temperture guage at the top?Your arrow points to low coolant. Yes.
Awesome!!!! Thanks so much. I feel so much better now knowing what all the lights mean! The coolant level is so low I can't tell the color....I must have mistakened the plastic reservoir right adjacent to the pattern changer for a coolant tank....must be the windshield washer fluid reservoir. I'll probably need to do a complete flush anyway and service.Top to bottom,
high beam,(not used)
Low battery voltage
Low oil pressure
High coolant temp
Air cleaner restriction
Low brake pressure (wheeled exc)
Parking brake applied (wheeled exc)
Autolube malfunction (option)
Crane lift overload
Quick coupler unlocked (option)
Pre heater on
On the right is shear mode enabled, hammer appears burnt out
Axle oscillation lock engaged (wheeled exc)
Low fuel
High hydraulic temp
Low coolant
Boom / arm float (option)
fuel heater (option )
