pjflyer
Just getting some input, Insley 560B, propel and hoe on same control block (dual spool system). Propel won't operate on it's own, but with hoe fully extended or retracted (over pressure), propel works fine. Hoe works fine on it's own. Worked fine in the past. In the process of getting correct size fittings for testing pressure. Any suggestions other than testing pressure?
