ahmedfotoh
I write code by esp32 board by Arduino ide platform which calculate the maximum load in kg that the crane can lift, or tipping load (I being used distance sensor (TF Luna ) to calculate boom length and two angle sensor (GY-521 MPU-6050 3 Axis Gyroscope Accelerometer Module) to calculate boom angle and turntable rotation angle and i use load cell sensor(Load Cell YZC 516C HX711) to calculate actual load in kg then I compare between that results to make alarm when actual load near to the danger ratio percentage to maximum load.
This is a hydraulic telescopic crane students project (the total weight 1000 kg and rotate 360 degrees and put on a steel frame 2 m * 1 m and weight 300 kg.I get these parameter :
1-crane weight
2- boom length
3-boom angle
4-slewing angle
5- load radius
6-boom weight
I need the equation of max load as a function of radius and slewing angle.
Many thanks for helping.
1-crane weight
2- boom length
3-boom angle
4-slewing angle
5- load radius
6-boom weight
