Self-Jameel
Pls folks I need help, too much air coming out of the engine crankcase, for a newly built (overhaul) engine A new turbo charger as well,what might likely be the problem
Change a new turbo cause the old one is faulty.further more I'm more disturbed cos it wasn't long I overhaul the engine in frame..Heavy crankcase blowbye is generally caused by problems with rings in cylinders, can also be caused by a faulty air compressor running off of the engine if it has one, or from a turbo dumping boost air into the oil return line in the pan.
That is all that I can think of.
Simon C
Have you built an engine before?I'm more disturbed cos it wasn't long I overhaul the engine in frame
But did you have any engine building experience before this build?Yes I built the engine prolly 3 months back.
