cfherrman
Man that thing is teeny compaired to what I was thinking lol, must be the high pressure that got me off.
There's a lot of 500-600 HP triplexs around here for acid and cement work, not sure on max pressure around 5,000 - 10,000 psi but 10 bbl/min. They are around twice the size with 3 1/2-5" plungers
Yeah some pumps are bigger the NLB 20425 I have also with N14 475hp is a bit bigger it's a Union power end but only does 34 gpm 20k.The 3 1/2 plungers can do 8000 psi for 600 HP. Ofm 600 is a common unit around here
Your is probably 80% physical size of what I was thinking, that last pic helps a lot. Those small plungers definitely keeps the size down
Ok no I haven't I'll need to check that good point.Have you verified pulley size on that pump? That Detroit was prob running at 2100-2300 when turning that pump. You'd better measure the pulley on your Cummins and figure out if this is going to work. Maybe you have?
I'm with these other guys, however. Chances are respectable that there are iron parts capable of 435, ***maybe*** 460 in your current 335, but I would never believe that engine will withstand 500+ hp in a stationary application long-term. No way. You will end up cooking it, even with CAC, if you even have that. FWIW, a bigger turbo is not going to save you. It might prolong the inevitable, but that's it. That engine will not have the timing or compression to handle that fuel.
Adding Gear displacement in a Cummins PT pump will gain you nothing but wasted fuel(Coal Rolling), a HIGH heat producer and eventually washed out cylinders from over fueling at off time and under bad performance delivery. If all you want is noise and smoke will get it. Want HP dependable and consistent have to go the WHOLE Nine Yards as noted, Injector Flow rates, PT Pump bench set, Cam timing and CORRECT Pistons for raise of Power Curve. Otherwise you get a Black smoking Grenade.
Playing I know what needs done with the Old Hands that have dealt with these engines for over four decades on here will get you ignored.
As noted prior, someone is blowing smoke out their hat for some reason. Don't trust us, we do not know squat or ever worked on Frankenmotors before.
Very possibly true because all they would do is change my pump gear clean the pump and charge me $600, it's not as if they are also working on the motor so the end result is a 500HP reliable motor it's just the PT pump.As noted prior, someone is blowing smoke out their hat for some reason. Don't trust us, we do not know squat or ever worked on Frankenmotors before.
I know how changing fuel pressure made a huge difference with my 5.9 Cummins in hp so to simply state it's gonna just smoke and wash out the cylinders by increasing fuel pressure doesn't add up.
