mitch504
LTA10 Cummins from about 1990 in an '87 International has developed an intermittent problem. Engine starts and runs very well, cold or hot. Occasionally it will cut off if you depress the accelerator too far too fast. If you veeery slowly press the pedal, it will go all the way to the floor and engine will perform fine. If it cuts off, it is just like you turned the switch off, no stumble no hesitation, dead. The thing that makes me think it is a pump problem is that it will not restart until the crankshaft stops turning completely. 9 times out of ten, as soon as the engine stops turning, hit the starter button and it starts immediately. No spinning, no hesitation, running in half a revolution. Sometimes, it will not restart, and the fuel filter will be only half full, but that has only happened twice. Both times, I filled it up and it started very quickly. When this problem starts. it will cut off anywhere from 3-15 times if you hit it too hard, then it will straighten up and be fine for ten days, or a week, or 2 days. I will get and post the engine numbers when I get back, I thought I had a pic of the tag.
This is a fertilizer truck, so it gets abused severely compared to most trucks.
