cylinder for quick coupler
Jim
China
Hi, anyone knows what is the pressure of the cylinder quick coupler? Is it the samw with the bucket cylinder?
Thanks,
Jim
elundell
Sooke BC Canada
Manufacturing Engineer
A company called leading edge attachments makes a quick coupler called the "wedgelock". Their coupler cylinder requires 3750 PSI
MrKomatsu
Houston Tx.
JRB makes a quick coupler.....the working pressure is the same as the bucket circiut...
Komatsu calls for 2000-2500PSI.....
drag1line
Houston, Texas
Be very careful with a general question like this.
Some couplers use bucket cylinder pressures and so, in the case of Komatsu this can be at least 5000 PSI...NOT 2000. Some couplers use pilot pressure and so the pressure in the cylinder will be less than 1000 PSI.
Check with your specific manufacturer of the coupler
