Shimmy1
9tc is the tractor 70v25461 is the engine, customer bought this machine 12 months ago and the engine gradually gets hot and so the transmission gets hot aswell on a 30 degree celcius day and above. seems to take a over 10 mins for it to gradually get temp down to say 85 degrees on engine 95 transmission. water pumps been replaced , thermostat, fan pulleys, radiator, coolers cleaned,
radiator replaced, transmission failed 12 months ago did a clutch pack, cleaned all system out then replaced trans scavage pump, t/c converter was changed three weeks ago to get on top of issues,
belly guards clean even took side engine doors off to see if would make a difference advised operator to put in neutral and have sitting at about 1500 rpm
Epirbalex
