xmongo96
I am looking to find the measurement spec for main axle shaft 2f-7576 (Dead Axle) on a Cat D5B 25x, wanting to know the distance the axle should protrude from the frame of the dozer to the end of the shaft once fully installed. Had the old one come loose and cause wear on the taper needing to make sure the taper does not need to be machined. Any info on this is much appreciated.
