The same electrical schematic uploaded by @kshansen in Post #8 will work for your machine.9DL00379 is the SN
#1 in the illustration below of the fuel injection pump is the shutoff solenoid. There should be a single pink wire connected to the end of it. With the engine running disconnect that wire and apply batt+ (12v) to the terminal on the solenoid. If it is working correctly the engine will shut off.How do I shut off manually?
