D5N possible electrical issue
Swampboy99
Central Texas
I have a 05 model D5N XL (I did not get serial number. I can tomorrow)
Machine has been cutting through and pushing limestone rock for the past month.
Today while tracking across the site every dash light other than the 2nd and 5th on the top row (no emblems left as it is open cab) came on, buzzer started going off, lost coolant temp gauge, lost tach reading, and it is stuck in auto shift
Dozer still runs great and is still able to be worked but I’m wondering what way I should proceed in diag on it
All fuses appear to be good, will double check with multimeter tomorrow and all grounds appear to be intact
I do not have access to CAT ET but have unhooked the batteries overnight just as a long shot even though I doubt it will do anything
I am assuming it is either a broken wire or loose connection. I did find a similar issue on another site but the only suggestion was to disconnect ecm wiring and ohm every wire to find the break and no fix listed
Thanks for any advice on the matter
Get a schematic and start looking for shorted or loose wires.
That's easy to say but it needs a Serial Number first, and to make it worse there are breaks in prefixes. I count 5 different electrical schematics.
Attached is some info on the Monitor and what all the warning lights mean. it was a stab in the dark and if your machine panel does not look like this then I'll need a S/No.
  • Monitor System.pdf
Zewnten
Earth
I just get tired of telling people to provide a serial haha. I wonder if they could change the forum to require one before posting a new thread.
Swampboy99
Central Texas
But in the OP's defence he did apologize for not providing one and undertook to supply it tomorrow.
Thank you for the attachment it is the correct one every light but the electrical system, engine oil pressure, fuel level and coolant level are on.
I do believe the serial begins in AGG but I am not 100% on that
Even a blind squirrel finds a nut every once in a while. The attachment was from an AGG-prefix Operator Manual.
Unfortunately there are 4 different electrical schematics for an AGG tractor depending on the exact Serial Number so you're going to have to come up with that.
Is the rectangular "window" in the lower left Monitor panel still working or has it gone on the fritz as well.?
Swampboy99
Central Texas
Only thing working correctly are the gauges minus the coolant temp it will read correctly until you start the machine and then it dies shortly after and then all the lights come on
Swampboy99
Central Texas
That is correct
Alternator voltage is 27.9 measuring off of positive connection on battery and negative terminal off master switch
Try measuring between the alternator + terminal and the frame. It should be the same but no harm in checking.
I'm not sure what to suggest after that. This needs input from the electrical experts.
Maybe once you get the schematic start pulling fuses for the gauges, monitor, etc, and see if there is any effect.?
Swampboy99
Central Texas
Same reading measuring from alternator to frame
I will double check fuses and then start scouring the wiring schematic to see if there is a common ground or main plug or junction for the issues
Swampboy99
Central Texas
Machine good to go
I pulled the fuse for the dash panel(one main fuse) and everything was back to normal other than dash working
Replaced the fuse and unplugged the connector for the 4 gauge panel and everything worked perfectly
Plugged the connector back and went to start tracing wires and everything was back to normal but the brake system light and serv code was illuminated
I remembered someone had to make a wiring repair in the past below the floor panel. I opened the panel and found a loose connection (previous repair was 2 spade connectors put together that worked loose) repaired it and everything is 100%
I’m guessing it is just a case of bad wiring repair and rough operating conditions
Nige thank you for the assistance on the matter it is greatly appreciated
Excellent news. I would suggest that you get hold of some Deutsch connectors and pins and go back and re-do that “repair” properly before it bites you in the *** again.
Even for single wire repairs Deutsch have what they call a Jiffy splice. You crimp a pin on one end of the broken wire and a socket on the other then simply pin both into the splice. Dirt, water, vibration and everything else proof. Not cheap though…..
To do the job the right way you will really need a Deutsch HD crimping tool and they are not cheap. About $400 for a genuine one although there are copies available for less.
Swampboy99
Central Texas
Dozer ran as it should for about 1.5hrs and then was shut down for 30 and about 5 minutes into running it the same problem has came back I’ve retraced every step I took previously and have came up with nothing
It appears I fixed an unrelated issue
I am going to start ohming wires to see if there are any breaks and will report back with my findings
