First, sorry to hear about your brother, its never good to lose someone, I have had a few people I know decease in that way,always keep his memory in your mind and no matter how bad things get during the day or on a project, this will keep it in perspective..........one would think it should work because it did before, all it takes is one little piece if dirt clogging a hole or passageway after you took off and reinstalled it...many times just moving something around stirs up something that causes trouble..dont overlook anything....but you just got good advice on how 3 dozers didnt work and the fuel pump was the issue on all 3 and you quickly dismissed it..so how long and how much would it be to pull the pump and send it out to get tested or rebuilt? Im not bashing you, but you have gotten really good advice that if you had to pay would cost you some $$$, and its not what you want to hear so you keep asking or looking for other issues...reminds me of a friend I had, he would ask 50 people till he got the answer he wanted and dismiss the other 49 people that said the same thing but not what he wanted to hear...and for the people giving the advice its almost like a slap in their face..just my opinion..if I dont know I will listen hard to those that most likley have the knowledge to help you out and get your dozer running again..Thanks so much
The fuel pump is a transplant from the original machine, it was working properly when I started to have all the problems with the oil pump going bad and ultimately destroyed the engine, not saying that something couldn't have gotten out of adjustment in the transfer. Just don't think that it is likely, being it was working properly before.Video might help diagnose. Thanks again!
I disconnect the fuel line at the injector while running the engine. The engine runs normal on all cylinders except #6.No drop on rpm on the other cylinders that I can see. Fuel is coming through the fuel line, good flow. No particular reason for swapping #1and #6,just the most convenient.
