I'm hoping to fix something for sure. There are 3 wire harnesses. One should be for gear selection. Thanks James
Your Diagnostic Code is nothing to do with gear selection. It is related to a limit switch that tells the ECM whether the position of the direction control lever is in forward, neutral, or reverse.
Did the result of diagnosing the Diagnostic Codes that I posted earlier indicate a problem with the switch in the directional control.?
But BEFORE going buying a new switch - and regarding 623.07 - did you do the test procedure below..?
Conditions Which Generate This Code:
This diagnostic code is recorded when status of the direction switch is wrong. When the control lever is in REVERSE, the Normally Open circuit is grounded and the Normally Closed circuit is open. When the contro lever is in FORWARD or NEUTRAL, the Normally Open circuit is open and the Normally Closed circuit is grounded. A diagnostic code is recorded when the status of the direction switch does not match the signal from the position sensor (direction selector). In these circumstances there will be no backup system for the position sensor (direction selector) if the sensor fails.
Note: Ensure that the CID 0623 FMI 07 is on hold and that the diagnostic code indicator shows "SERV CODE".
Test Step 1. CHECK THE DIRECTION SWITCH.
- Check the screws that hold the direction switch to the console for the FTC. Tighten any loose screws.
- If the problem persists, loosen the screws on the direction switch and rotate the switch slightly.
- Tighten the screws. Change the direction of the machine and then determine if the diagnostic code is still present.
- If the problem still exists, loosen the screws on the direction switch. Rotate the switch in the opposite direction slightly.
ONLY if after Steps 1 thru 5 the Code has not been eliminated would I replace the switch.
In fact if you read the Steps closely the most likely culprit is - loose screws........
The 2nd most likely is the switch slightly out of adjustment.
$4600 for a fix - my ***.....!!!
